Will Red Dead Redemption2 work on my PC
carnagelan
I see steam has a special for R499 from R999. My cpu will work but not sure about my GPU
Specs are
Ryzen 5 3600
ram 16gb ddr4
GPU gtx1650 4gb
I am just worried about my GPU and if i will get low or medium quality.
Thank you
Buy it. Install it. If it doesn't work request a refund. As long as you don't go over the max. play time (owned for no more than 2 weeks, played no more than 2 hours) specified for a refund.
But thats the thing. Minimum and recommended are the same specs
Those are wrong. These are the minimum specs according to R*'s website:
Minimum Specifications:
  • OS: Windows 10 - April 2018 Update (v1803)
  • Processor: Intel® Core™ i5-2500K / AMD FX-6300
  • Memory: 8GB
  • Graphics Card: Nvidia GeForce GTX 770 2GB / AMD Radeon R9 280 3GB
  • HDD Space: 150GB
  • Sound Card: DirectX compatible
Buy it. Install it. If it doesn't work request a refund. As long as you don't go over the max. play time specified for a refund.
Thanks man, I didnt know you could get a refund on steam after opening the game ?
  • Memory: 8GB
  • HDD Space: 150GB
Thank you, :)
It played fine on my 1070 and i5-2500k a few years back. You do need to turn settings down but it's playable.
It'll work, but you'll need to set it to low cause the 1650 isn't high up
They added FSR 2.0 support a month ago, you'll get 60FPS on medium settings, probably around 80FPS on low.
