mosquito5
Hi i bought a pc from a friend of mine. It has a acer rs780hvf motherboard. I want to buy a HD6850. Will the card work on the slots provided on the motherboard considering the PCI-E version on the board?
Amd athlon processor 1640B and i have a CoolerMaster RP/RS-650-PCAR Extreme Power Plus 650W. If i am correct the mobo has a PCI-E 2.0 port and the card requires a 2.1 pci-e slot will it work and will it fit in the slot?Hi & welcome to the forums.
That motherboard (on which I can find very little information) has a PCI-E 16x slot, so the HD 6850 will work just fine.
Could you perhaps tell us what brand & model power supply you have, as well as the CPU's model #?
What do you intend to use the graphics card for? CAD / Games / etc.
I will be using the card for gaming
