Will this Android STB work with DStv Now?
PaulB_
Hey guys.
Looking to purchase an Android STB from Aliexpress, strictly speaking this one here http://www.aliexpress.com/item/D1-Android-TV-Box/1901883463.html
Would this be compatible with DStv Now?
Reason why I chose this was specifically for the AV Out, so content can be recorded onto my HD Recorder, and fed around the house....
Just wondering if the unit itself would be compatible with DStv now?
The build.prop may need to be tinkered with, to think it's a samsung device, and that's something I know how to do, but I'm just checking if the hardware is correct, and it has the required DRM software to process it.
Hey guys.
With only 512MB RAM and those specs, DSTV Now is the least of your problems.
You can get an RK3188 for around $40-$50 that is much better.
