Will USR 9108 router work in SA
can't look at the router specs cos IS int is down .... again ..... :( :mad:
AFAIK, and I am certainly no expert, the modem will need to support G.lite to work on Telkom's DSL.
i'm 100% sure it will work with telkom like as most of new ADSL modem/routers can support muiltstandard (not many ADSL chip manufactures in the world).
but the problem is, the device is target to north america market, the adaptabilty is designed for that region, you might encounter the line dropping issue if you use it here.
i just wondering what's sepcial of that router makes your decision. there are lots of brand available here, and have been approved by hundreds of local users.
but if you can get it for FREE ...
