Wimax Problem
Stiletto
I have been using Telkom's Wimax for just over a year with almost no problems. Well thinking about it I had 0 problems so far.
Until 2 days a go ....
When I dail my pppoe connection I get a "error 651" message.I have connectivity towards my equipment . Can ping the device , even open it using IE and check settings and signal strenght and so on , so everything seems fine.
Thinking it might be my desktop I recreated connection on my laptop , but to no avail , same error.
Has anyone maybe experienced the same scenario ?
What is the correct ip setup for the desktop, if mine is wrong ?
IP Address : 192.168.254.10
Subnet : 255.255.255.0
GW : Used no gateway as well as 192.168.254.251 --- no success
DNS : Used no dns as well as WebAfrica dns servers --- no success
Any advice will be appreciated. :)
