Win 2K and XP need help
sofi
Durban
I need help with my problem
I have several accounts with my ISP. I have conected to the router but have not entered the username/ password in the router instead I have setup a connection in XP using the option "conect using broadband that require a username/password" on each computer using a different account and it works perfectly but for 1 of my machines that is running Win 2K, that option is not available. Is there anyway I can set it up so it can do the same as in XP?
any sugestions will be appreciated, thanks
