andres101 said:enable encryption (longer encryption key = more secure & slower speeds)
gkm said:Disabling SSID and using mac filtering are both a waste of time. Wardriving software will still see the access point and can easily use the MAC of your real friend to get in. So, you are just making life harder for yourself. WEP is also mostly a waste of time. Use WPA with a password of at least 30 characters. I was able to set up WPA in 2 minutes.
digital said:Thanks for your replys.Now i have stupid question.If i disable broadcasting ( i have that option),how will my friend see my AP ?
buster said:Now for someone to actually want to hack into a router, they either want free internet access really really badly, or they have way too much time on thier hands.
Karnaugh said:that doesnt mean letting it happen is a good idea.
Enable WPA, its the only way to go. MAC addresses are very easy to spoof, and getting ARP poisioned isnt fun either.
digital said:Please ,help some not very bright people.
On my Netgear 834 G router i go into Wireless settings and in security options
i choose WPA-PSK (Wi-Fi Protected Access Pre-Shared Key).Then in
Network Key (8 ~ 64 characters) i enter 10 digit key just to try.Press apply.Done on my computer. Now on my friends laptop in View available wireless networks i can see Available networks - NETGEAR which i suppose is my router,but when i try to connect,it does not. In My friends
computer under wireless Network Connection properties i have Netgear under
prefered networks and under available networks.Then in Netgear properties
under prefered networks i have a tick in Network authentication box and i put
10 digit key from the main computer. What i'm doing wrong? Thank you for your help.
