wpswart006
Good moring all,
I have the following dilemma:
I live in a complex that falls under a local WISP's hotspot. I don't know enough about network protocol to explain what they setup they use, but I can tell you it's an open network, that you have to sign in to from a browser on any device you use.
What I want to know is, is it possible to set up bridge between the hotspot and a network inside my flat?
In other words, is there a setup (router) that can handle the web sign in, and then bridge the network to devices inside?
Any help would be appreciated.
Regards
EDIT: After some reading it seems that they use a captive portal.
Regards
