Nikki Nina
Hi there
I am so frustrated I could scream!!! I have a tiny (2 pc) wireless network setup at home. My laptop and an internet pc are (were!!) connected. We started experiencing ADSL errors and called Telkom in to check the link which they found no fault with. The wireless connectivity however remained excellent, we just lost the outbound link from time to time. However, when the Telkom man left, my laptop was suddenly disconnected from the wireless lan. It was on and connected in my office when he got here - router in the house. On trying to re-establish the link, I discovered that all the router settings were gone. I checked with him, he knows nothing about it even though suddenly a new network appeared in my list.
I resetup the router and have tried using the same SSID name to connect from my laptop and the other pc and both are experiencing the same problem. Although the WPA key has remained the same - seems to be automatically inserted in the router settings - we have re-entered it on both pcs but with no luck. We get intermittent connectivity until somebody tries to enter a web site where you have to enter a password and then connectivity is dropped. I am currently working through a patch cable (usb) plugged directly into the router. The laptop nic connectivity light goes off when the link is dropped. If I view the network in my connections, it shows that it is acquiring an ip address. If I run ipconfig when the link is lost, I can only get an ip address for the usb connection, no ip address assigned to the wirelss nic. When the wireless link is up, then an ip address is assigned.
I have tried resetting the router to default settings and using a new SSID , but still no joy. THis is driving me crazy. Have had no joy through Telkom. Please, if there is anyone out there who may be able to assist, I would be hugely grateful.
Thanks ahead
Nikki
Thanks ahead
Nikki
