Wireless Connectivity Tester
Jizzims
Banned
Morning dudes
Do you guys know of any software // Hardware that i can monitor wireless network reception from a Wireless router ?
also try ekahau heatmapper. You walk around with your laptop and plot signal reception on a pre-drawn floorplan. It then generates a heat map of signal strength. Very cool.
I have also used my itouch, I cant remember the application, but it was great at telling me info about the signal (direction . strength etc.), however it did not have a plotter. I would also presume it works on the iphone, but seeing as I dont have one I dont really know ...
netstumbler doesn't support my dell laptops wireless card so I found a little vista desktop gadget thingy from http://www.xirrus.com/
works fine for me.
will look into heatmapper, sounds funky
Brilliant because i need to go to a complex and map out signal on 2 floors ?
