Wireless G or Wireless N
dd1313
Are most laptops in our country Wireless G or Wireless N ?
DD
most are Wireless G by far. I'm not 100% sure if wireless N is official now (can somebody confirm?), but for a long time you could get "draft wireless N" devices which did not implement the official N standard but was different companies own version of N which is not necessarily compatible with the final official standards, or with other manufacturers N devices. So lets say a Belkin wireless N router could only work with a Belkin N card, but not with a Linksys card, etc. I hope that is changing now...
The N-standard has been defined and made fully official since sometime last year already, so incompatibility between brands should be a thing of the past by now.
I switched to using wireless N at home, but it has problems :
1) Range much shorter in house.
2) None of the older notebooks support N, and some of the newer ones only support 2.4GHz N (eg my Asus 1000HE netbook).
So I am using a dual-band router (Netgear) supporting 2.4GHz G and 5 GHz N at the same time.
It works OK. The N band is very fast, close to 300mbps.
Funny, I have the exact opposite experience in terms of range using N (I have one of the first Draft N wireless access points that came out in 2007 - the big Netgear white box thingy). I get MUCH further range, even when connecting to it using a G card in my laptop. When buying a new wireless router, i'll only take N if there is one available. It's backwards compatible with G, so no issues there.
EDIT: By "It's backwards compatible" i really mean, the access point I have connects to G without a problem.
I've also got a Netgear(dgn2000) router and my neighbours pick up my network, we talking atleast 40 meters which is pretty good IMO..
So make sure you set up a good password on your network :)
EDIT:
Just a question on Wi-Fi Protected Access which is better WPA2-PSK, WPA-PSK or WEP ?
It offers me the above 3 as well as Mixed WPA-PSK+WPA2-PSK which i've chosen.
I also pretty much have to change all my computers to N, because I am installing IP cameras that use G, and each of them uses a channel, so I will run out of G channels.
The old notebooks will be a problem in this respect, unless I use them with N dongles.
I tried updating the Mini PCI-E cards with N cards, but it didn't work so well, it seems that the built-in antennas in the notebooks are highly optimised for the cards that they come with.
