Bose AE2w would be my choice, light overear, has the option to plug cable if battery fail, then you can connect 2 devices simultaniously (notebook and phone) and listen to music, when phone ring, music pause/mute, have conversation, afterwards it unpause.
Problem is R3500.
Sound quality is great, 2 negatives would be, can't go that loud, and little less bass than i would like. My Philips has beter sound. (But thats wired)
Then the Philips BT set would fit in your budget, but it is a on-ear set.
I had Creative BT aswell, but not that impresive...
I would say the Bose was the best i've used in the BT department...
