colin87
Hi Guys
Here is my issue.
Telkom screwed me over, so I cannot get ADSL, as the exchange is full. Now I'm forced to use the wireless internet in my complex.
Problem 1, I have a combination of wireless and wired devices in my flat via D-link router. Can you "Bridge" two wireless connections, so I can use my local network, as well as connect to the Wireless Internet AP they provide?
Problem 2, The signal strength is poor in my flat. My options are either to use a repeater, or use Hi Gain antennas. I'm not sure which will be the best route to go, as they are similar in cost. The repeater though, gives me the same problem as above, I need to bridge the two connections somehow.
Here is my issue.
