Hi I need help please. I purchased a Gigabyte AirCruiser G access point and set it up at work and tested with my laptop and it all worked fine connecting no problem. I took it home and plugged it in but laptop refuses to connect at home showing incorrect passkey in the event viewer. Yet I had not changed it from the settings I tested at the office. I tried setting different channel no joy. The only way it would work was turning all security off. I took both back to the office today and tested again and it works fine there. I have disconnected anything wireless near my pc at home yet still no joy. Any Ideas Please.
The problem is obviously between your work and home.
The only way to resolve this is to find out exactly at which point during your journey home from work it stops working.
You then need to move house to the area located just before the "non-working" area.Hopefully this area is not a squatter camp but even if it is, it wont matter as you will have working wireless!
Or you could try using a 3rd party wireless app like NetStumbler to test.
I would go for the first option though, much easier.
