wireless network setup help
billym
i need help setting up a wireless network in my business i have 3 businesses on a same street
heres a diagram
site 1 site2 site3
site1 to site 3 1km distance buildings and trees in between
site2 to site3 50m distance
site 1 has adsl
would like to share internet and files
what would be the best hardware to link these 3 sites
thanks
heres a diagram
site 1 site2 site3
site 1 has adsl
thanks
with buildings/trees in the way, going to be very difficult.
Actually, that rather depends on *where* the trees are: trees right next to a building (i.e. right by the radiating antenna) have a far greater effect on blocking our signal, where trees in the middle of the path (where said path is even 1km) are likely to be negligible in effect.
The effect of buildings is much the same in principle, only to a greater effect: if you're stuck with a *big* multi-storey structure in the way that's got you well beat in terms of height and width then yea, thing are definitely going get ..interesting.
IOW billym- significantly more info please! ;)
-bdt
-bdt
yup billym need more info before we can answer you
