Wireless on HP Compaq NX 9110
georgelza
Johannesburg/Alberton
Hi there
having problems, for some reason it keeps on saying the wireless network system is dysabled,
I am running Windows XP Pro, The wireless card is being reported as the Broadcom 802.11 b/g WLan
anyone got experience getting this to work ?
G
You Have The Obligation to Inform One Honestly of the risk, And As a Person
You Are Committed to Educate Yourself to the Total Risk In Any Activity!
Once Informed & Totally Aware of the Risk,
Every Fool Has the Right to Kill or Injure Themselves as They See Fit!
Hi there
You will have to provide more info. Is there a wireless network you want to connect to? The best spot to put the question would be at http://www.myadsl.co.za/forum/forum.asp?FORUM_ID=27
I am not going to move this Q there yet, but do yourself a fav and repeat the question there again. [8D]
Regards
Antowan
### What we need in South Africa is cheap 24/7, always on Internet for under R300 a month. ###
Hi George
Are you trying to connect to an access point? Have you checked whether the "Wireless Zero..." service is started? Have you right-clicked the network icon in the system tray to enable the card?
Hi there,
Wireless zero says it got nothing to configure further when i try and start it, as for the card it is enabled, i can so far as that the card picks up the SSID transmitted by the Netgear DG 834G, when i make security changes on te router regarding the wireless security the Broadcom card picks this up,
it is just saying connection unavailable... weird.
G
