Hi All
I'm looking for a solution to send the audio signal from my Sony amp, located at the front of the lounge to a set of speakers (rear left and rear right) at the back. They will be mounted on or near the wall and any transmitter/wireless speaker that requires power will not be an issue (~1-2m from a power source).
However, I do not wish to run cables across the lounge for these two particular speakers.
Can anyone recommend a solution, be it a wireless transmitter, to the existing speakers (which do not have built in amps), from the audio out on the amp; or, wireless speakers (again, from the audio out on the amp).
Any suggestions?
Thanks!
Any suggestions?
Thanks!
