Wireless Router for iBurst
HeXetic
I'm looking for a Wireless Router that you can plug the iburst modem into and the router will automatically dial out for you. I'm sure you get such a thing but i'm not sure which ones are compatibile with iburst.
The UTD should be compatible with any router that supports PPPoE, using the RJ45 connection.
I use the LinkSys WRT654-GL - but there are others. (I just loved the idea of being able to change the Linux firmware ;))
Avoid the Linksys WRT54G v5. It has many limitations.
TP-Link
You could also check out the TLR860 from TP-Link. But once again, it will only work if you got a RJ45 connection from your IBURST modem.
Jongi has a good point. PC Mall has the GL, which is basically a rebranded WRT54G v4... without the v5 limitations.
I use the D-Link Dl-624 it has 4 lan ports and wireless. I haven't had any problems with it and I have recommended it to a few of my friends and they too are happy with it.It can be hard to find and pricey though.
I have a Netgear 614, it does rock. but basically where ever you are buying this from, just get a router that supports PPPOE and has a RJ45 (Ethernet) connection. Usually the ones with a built in ADSL modem wont work with Iburst.
Teh brand or model is pretty much preference and extra features, all routers can do what you want from them.
