Wireless tie pin microphone wanted
Do you want one that works with an FM radio? Have one which has about a 15m range, but its best if you can see the radio to which it sends. Then you plug the headphone output of the radio into an amplifier. The battery is new and I have a spare one somewhere
It is called a tie-tack microphone. Has an on/off switch, trimmer for adjusting the FM frequency between 88 and 108MHz and a fairly long aerial - about 300mm
Price R 50,00. I am in Cape Town southern suburbs
I dont know... I know its those tie pin mics(clips on your shirt) and one end goes to a transmitter that takes batteries which send signal to an amplified speaker... Then speak and you hear it through the speaker
Will your mic work?
Well, R50 is giving it away. The ones on BoB start at about R 1200 but are obviously better. This one works, I have 3 and have used them giving talks, etc
The consideration is that you need to have line of sight to the radio and this must be as high as possible. I think the transmitted power is very weak, maybe 1/50th of 1 watt
