CranialBlaze
- Jan 24, 2008
Busy setting up a file server at work and am having trouble with its WoL. Worked fine when I turned it off in the GUI, but when I switched to Command Line it became somewhat of a hit and miss, more miss.
Its using ubuntu 12 and ideally I want to be able to turn it on from my house so have a dyndns setup, firewall rules are correctly configured and even sat monitoring tcpdump on port 9 and every WoL packet I sent arrived, but as soon as I turned it off it I could not get it back on again. I know the DynDNS is working fine as I can tunnel/ftp in without any problems
I am pretty sure its possible to use WoL over the internet, plenty of googleing supports that Idea but it is the first time I am trying it out. I do know if the wrong power state is used on shutdown then WoL is useless, had soem trouble with Win8's new "Fast Boot" feature, something it did made WoL useless, until I found and disabled it.
I have tried "shutdown now" "shutdonw -h now" and "poweroff", "poweroff" seemed to work better.
Anyone have some experience with this, would prefer not to put this pc on a boot schedule in the BIOS.
