Wooden window frame repairs
f0xZA
Just wondering if anyone has recommendations for someone who can repair broken/rotting wooden window frames?
Thanks!
ToxicBunny
Oi! Leave me out of this...
To be fair, it will probably be better to just replace the entire frame if they're broken/rotten to any great extent.
f0xZA
Repair / Replace - lots of hits on google just wanted to know if someone has dealt with anyone that did good quality work ...
ToxicBunny
Repairing them is a big job... just forewarning you, and I think guys with the skill to do it properly will be few and far between and expensive unfortunately.
The_MAC
Trust me, just replace them with aluminium, its a bit pricey but are maintenance free and they seal properly when closed, plus its easy to install burglar bars on them etc.
I bit the bullet and had all mine replaced, well worth it.
I loathe wooden frames, especially in the bathrooms. Not to mention the fact that they are prone to ants/termites.
f0xZA
@ToxicBunny I don't mind replacing them, when I mean repair im talking about one hinge specifically that is a problem but frame is fine.
@The_MAC Unfortunately not an option as we are part of a complex
The_MAC
You get "wood pattern" aluminium, is that not an option?
f0xZA
Popped off a mail to the body corporate to see if they have vendors and if that would be an option ... thanks
ToxicBunny
Ahhh if its just a panel of the window and not actually the frame, then it should be relatively simple and cheap to do.. you can probably do it yourself with some basic wood working tools.
panayi
who did you use and would you use them again ? I am interested to replace some of my wooden windows - they just don't seal properly....
