WORTH GOING 512 UNCAPPED & UNSHAPED?
witchking
Hi All
I have 1mbit iBurst Wireless and wanted to upgrade to 4mbit uncapped only to be told my exchange does not support it. Is it worth going mweb 512 uncapped & unshaped? Can anybody give me an indication of the download speeds attainable?
Many Thanks
You will get between 50-60Kb/s and could do around 130 gigs a month. youtube will need to buffer but not for aslong as 384.
Uncapped definitely, Unshaped if you have lots of money to throw at your ISP!
Depends what you want to use it for, as there are several bypass services under your nose here on the forums, to make full use of your P2P downloads on a shaped account, for a small amount. But if you're planning on using a different port, that might be shaped, then I guess you will need to get unshaped.
