NomNom
Hi all I would like to know if this "design" would work in my Thermaltake Level 10 GT case.
My worries are:
1. Would the pump be powerful enough?
2. Would it cool the system enough?
3. Is everything compatible?
If you can suggest different parts or method that would do a better job please do.
Main kit:
-XSPC RayStorm D5 AX240 WaterCooling Kit - Support Intel Sockets LGA2011, LGA1366, LGA1156, LGA1155, LGA1150, AMD Sockets AM2, AM2+, AM3, AM3+, FM1, FM2
-http://www.pbtech.co.nz/index.php?z...RayStorm-D5-AX240-WaterCooling-Kit---Support-
Extra radiators:
-XSPC AX120 Single Fan Black Radiator- high performance copper/brass radiator core with a compact and beautifully finished aluminium enclosure (Fan not include)
-http://www.pbtech.co.nz/index.php?z...AX120-Single-Fan-Black-Radiator--high-perform
Compression fittings:
-XSPC G1/4 to 7/16 ID, 5/8 OD Compression Fitting (Black Chrome)
-http://www.pbtech.co.nz/index.php?z...G14--to-716--ID-58--OD-Compression-Fitting-(B
Hose:
-XSPC HighFlex Hose 15.9/11.1mm, 7/16 ID, 5/8 OD, 2m, Clear/UV
-http://www.pbtech.co.nz/index.php?z...HighFlex-Hose-15.911.1mm-716-ID-58-OD-2m-Clea
Liquid:
-XSPC EC6 High Performance Liquid Cooling Premix Coolant - 1L - Blood Red (Made in the UK)
-http://www.pbtech.co.nz/index.php?z...EC6-High-Performance-Liquid-Cooling-Premix-Co
My worries are:
Main kit:
Extra radiators:
Hose:
Liquid:
