wrath key info?
gumpie
Midrand
Hey guys....
I got the client from a mate as mine was totally messed. I had to load a 40mb patch to get it working... I can log in and everything...
The question to ask now is can i just buy a key online from say gamersloot and upgrade my account or will i need to install some more stuff?
Thanks?
Effectively you can copy the game straight from a friend's pc to yours with no additional installations.
Keep in mind, there's a difference between the client and the account. You can play on anyone's pc and anyone can play on yours.
when you have all the content on your pc, you simply tie the new key to your account on their website. this grants you access.
If the client is outdated it may want to pull patches etc, but otherwise you should be set to go.
O.k cool..
I just wanted to find out cause i could actually play last night.
So where would be the best place to get the key?
Hey guys....
Thanks?
Buy the upgrade directly from blizzard USD39.99 as opposed to USD59.90 from gamersloot.
ARRRRRGGGGGG.
The client i had did not have wrath installed but only the pre patch.
Is there any1 near the midrand area that would have the install for me as i already brought the key....
