wrt54gl problem connecting to adsl...plz help :)
headstrong
hi
I have my wrt54g in AP mode
my wrt54gl (with dd-wrt v23sp2) in client-bridgemode to the wrt54g connected wirelessly
my adsl modem in bridge mode connected to the wrt54g via Ethernet
..... I can share files accross the network but I cant connect to adsl!!!
Does my wrt54gl need to be in client mode as apposed to client-bridge mode? or what is the problem?
Thanks alot!
hook the adsl into the wrt54g wan port
on the wrt54g setup the pppoe settings there
have the wrt54g DHCP enabled
that should work for all machines connected to either router
thanks bboy but I want each individual machine to make their own pppoe connection because we will be using our own adsl isp accounts.....
kloon, what would I set the gateway ip as? the adsl modem or the AP(wrt54g) or the wrt54gl ?
