X box 360 media center help!
DewaldB
Ok so I set up my media center from xbox so that it streams from my pc and it works perfectly. My problem is I have normal movies with not so good quality and then a HD collection and tv shows. Now I want to view everything on the xbox but what I cant seem to figure out is my menu. I shared everything and now everything is showing in my movie library ex. tv shows movies everything is out of order I would like to have tv shows and hd movies seperate becuase it looks like this now
Avatar 01 01 01 02 02 02 Band of Brothers 03 03 03 (and 01=smallville 01=simpsons.)
Sorry but I dont know how to describe this any better.
Got it sorted in a way.
I added all my other stuff as videos and my HD movies as movies so now I view the movies where it says movie library and all the other stuff where it says Pictures+video.
If you think thats cool google Media Browser. I also use the Xbox 360 to view my video library... but with this plugin you get stuff like cover flow and more and all for free.
Thanks man this is awesome.
O now have alot of pictures that it retrieved but the only problem I now have is that some of my movies pictures is nor right like Dawn of the Dead it got the 1970 version pic any way of changing.
Yes you can I use Media Center Master to get my metadata(Pics & Stuff). So don't use Media Browser to fetch that data. The best way to get it right is by adding the year of the Movie next to it... e.g. "Ninja Assassin (2009)" this should help the app find it quicker. You can also set Media Center Master to rename the for you. I hope this helps and remember "GOOGLE IS YOUR FRIEND" !
