Hi,
I have been battling for 2 weeks to try and get the navigation and play/pause buttons on the K300 remote to work correctly within XBMC. I have tried the K300 remote with Windows 7 MCE and everything works as it should so the remote and the USB receiver works, drivers are correctly installed, etc.
I am running XBMC 10.1 and only fast forward, rewind, stop, volume up, volume down and the mute buttons work as they should from within XBMC.
I can start playing a movie using my mouse and then if I press play/pause the movie will pause, if I press play/pause again nothing happens, to start playing the movie again I have to use my mouse and clicking on play in the OSD.
I have posted a request on the XBMC forum but everything that has been suggested does not work. I have tried Showkey.exe and KeyMapedit.exe, still I cannot get a movie to start playing after it has been paused by using the K300 remote.
So if anyone can please assist me with their working copy of the XBMC keyboard.xml or a keymap.xml for the Compro K300 Remote, I would greatly appreciate it?
Thanks in advance...
Paul
Paul
