XBMC Installation Resolution
Sparky_za
Hi Guys
Having a bit of a problem trying to install XBMC. Setup is an HP Microserver with an Asus GT620 installed. On installation though I am trying to use the onboard VGA output, so I have changed the BIOS setting to "Always On". Output during POST is fine to the monitor, and when I see the purple screen pop up I press enter in order to access the menu. Then select 120x120 resolution for installation, but the first screen it gets to after that I cannot see any of the buttons "OK, Back, ETC"
Unfortunately I don't have an HDMI monitor here at the office to try that output; I wanted to run the installation here and do all the updates etc, and then take it home and connect it to the TV via HDMI.
Any ideas for things I could try?
