scuzzy
Ahoy,
Hope someone can assist with this very annoying issue:
I am in no way able to connect my Xbox and PC to each other.
* The Xbox does not detect the PC at all
* The only place where I can see the Xbox from the PC is through the Network Map in the Network and Sharing Center. WMP does not detect it as a valid source to 'Play to..'
Some info on my setup:
* Xbox connected with ethernet cable to router
* PC connected via USB Wireless adapter to router (could the issue be the different connection mediums?)
* DHCP assigned IPs
* Sharing and network discovery options all enabled.
* Windows 7 Ultimate Build 7100
The Xbox can connect to Xbox Live without any issues (and obviously detects the network as well)
Any ideas?
Thanks!
* DHCP assigned IPs
Any ideas?
Thanks!
