XBOX 360 SLIM Liteon Drive Flash
Rjvm
Good day to all
I have an X Box 360 slim with a. Philips Liteon Drive Model number DG-16D4S FW Ver 9504.
My question is how can I flash my drive using a SATA to USB cable ? I have downloaded jungleflasher, would I require any more software or cables?
I'm a total newbie so I need some sound advice.
The drive is out btw.
Thanks in advance
You would not be able to do it with only those tools. You will need tools to either drill a hole in the board or read the key with(Not sure of the process for your drive, mine had to be drilled into)
Only the old phat xboxes could be flashed with jungleflasher and a normal sata mobo. My advise would be to just pay someone that has the experience and so that you don't mess up your own stuff.
Also the correct firmware that plays the new games have not been released for the drive you have.
http://c4evaspeaks.com/ for info regarding the firmware
Darn. I'm in Durban. Do you know anybody who can do it for me in durban?
