Xbox 360 Wireless controller losing connection even if cable is used.
benitok
Need some help. My Xbox 360 Wireless controllers are losing connection even if cable is used. It is happening more and more now. I thought it might be interference so I changed the channel my Wi-Fi controller was on, but the problem is still there.
Usually it drops the connection and comes back straight away, but today it lost connection and did not want to reconnect, tried my other 3 controllers and they also did not want to connect. Tried one with the usb cable and it also did not want to connect. I had to switch off and back on the xbox before they all worked again.
I assume this is a problem with the console. Any ideas?
So you fixed it the way a Microsoft product needs to be fixed. Switching it off and on again.
I have a Xbox360, never ran into this problem, though.
