XBOX Cable Q
Blah
Which cable would I need to connect to my Samsung T240 24" PC monitor?
And would this cable work in a TV aswell? Do I just need an HD cable?
THANKS!
You can use either of the cables to obtain max resolution of 1920 x 1080 / 1080p since the Samsung T240 has analog RGB, DVI, HDMI inputs, but depending on the rest of your equipment the VGA cable will be the best option since it features an optical connector at the back of the Xbox connector to provide Dolby Digital audio through a capable receiver. Supported resolutions on the cable are 640 x 480, 848 x 480, 1024 x 768, 1280 x 1024, 1280 x 1024, 1680 x 1050 (With Xbox 360 NXE Update) and 1920 x 1080. Our company does have these cables in stock as well as HDMI Category 2, HDMI v1.3 rated cables if your receiver supports HDMI audio decoding and you wish to go this route. If no receiver is used the Xbox VGA cable is the best bet and the Stereo Analog RCA connectors can be used for audio.
