Juggy
When trying to login to Live it fails and when doing the the test the MTU fails.
Any idea why?
Any idea why?
That's why I said "or"...Aha, thanks. Surely if uPNP is enabled the router will open the ports itself?
Good stuff.
Oh, and use Comodo firewall for your PC seeing as the router's firewall is now disabled.
No clue, I only know how to set up the router for Live, not all the other stuff.Can I not get around that by setting up the router firewall properly.
No clue, I only know how to set up the router for Live, not all the other stuff.![]()
If you get it right to have the router firewall disabled for Live but have it working for the PC please post the details here, I'd also like to have that kind of setup.Sweet, I'll have a tinker this weekend.
Funnily enough it worked fine with the firewall enabled on my Netgear. As soon as I decided to use the Telkom 200 it stuffed up.
Typical.
