I did it by just sharing the 3g connection on my laptop and my xbox picked it up and off it went...
Is there any specific IP, etc settings? If i set it to auto detect, would it work?
At the moment i'm connected @ 384k via my router but get serious lag issues so I thought i'd give 3G a try.
If that's not the problem you may also have a crossover problem. - ie network cables are designed to run from device to hub, if you're connecting device to device, the cable needs to be a crossover cable, unless one of the devices can autosense, which is often not the case.
