Howzit guys,
I'm looking at buying a VGA cable so that I can connect my 19" LCD to my Xbox, but I came across this today:
Have these problems been fixed or are they still an issuePROBLEMS:
There are 2 problems with the cable:
1) MAJOR: Interframe update tearing results in a line across the screen showing half-previous and half-current frames creating an annoying feature I thought was long gone since the days of PC graphics cards in the 90's.
2) MINOR: PAL-50 old XBOX games cannot be played using this cable. As most XBOX games were made for PAL-50 (instead of PAL-60) you will NOT be able to play those games using this cable. You'll need to switch back to the component cables instead.
