Xbox wireless N adapater connection issues
justplain
South Africa.
I've just got a brand new official Xbox Wireless N ( the Black twin antenna variety with 5Ghz support) and I'm having endless difficulty connecting it to my new Billion 7300w 2.4Ghz 150Mb wireless N ADSL router.
I have 2 pcs'/laptops connected to it flawlessly via the wireless, but I cannot get the xbox wireless N adapter to connect.
On the xbox the wireless network is detected and shown ( my ssid is not hidden ) as well as other nearby wireless networks.
I use WPA2 and AES as the encryption type. ( recommend by MS "Use WPA2 if possible: The best wireless encryption to use with your Xbox 360 console is WPA2 with AES encryption. " http://support.xbox.com/en-us/pages...twork.aspx?kbid=978945#WirelessNetworkAdapter )
I enter my network password on the xbox and it tries to connect to my network but it says it cannot connect to the wireless network.
My Billion 7300w is configured to 802.11 g+n.
DHCP is enabled
The odd thing however is that it will connect to my older Billion 7300ga 2.4Ghz 54Mb wireless ADSL router, configured using WPA2 and AES, with the same password, same DHCP scope and set to 802.11b+g ( it's default setting )
I've tried setting the newer Billion 7300w to 802.11g, 802.11b+g, 802.11g+n and 802.11b+g+n with no luck.
any ideas?
I'd rather be using my newer 150Mb Wireless N adsl router than my older 54Mb one...........
Are you using MAC filtering?
nope, but i think I've narrowed it down.
I cant connect the Billion 7300w to the xbox wireless N using WPA2 or WPA2-PSK, it will only connect using WPA.
that is strange, because It will connect to the 3 year old Billion 7300G 802.11G using WPA2....so i'm a little stumped on this one right now.
updated the Billion 7300w 802.11N router to the latest firmware too....didnt help.
well it's working now on WPA...but more testing to come I think, I'd prefer to be using WPA2.
I know its an old thread.. but this helped me solve my issue with Billion 7300w router issue with XBOX.. same issue.. got resolved when I changed to WPA!!!
