Hi peeps,
I have the XFX 8800 GTX card. I believe you can update the Bios to get you the Ultra's performance. The only website I found with XFX Bios Updates is:
http://www.mvktech.net/component/option,com_remository/Itemid,26/func,selectfolder/cat,70/page,16/
The link to how to actually update it is:
http://www.hardforum.com/showthread.php?t=1199078
My Q to you is:
How do I know what Bios to update to? What do I do to make sure that after the Bios update the card will still work?
My Q to you is:
