Xiaomi Mi Box S review
moedawood
Hi guys. Im interested in the mi box S. Any reviews from the people that purchased it? Is this box worth it just for streaming? Is the 8GB enough storage if you're just streaming? Thanks.
Apologies if a thread exists. I couldn't find it this I created this one.
As far as I know it's the same hardware as the previous version. I do have the previous version and on the previous version the answers are yes and yes. I use mine daily for steaming form Netflix & showmax. It also works with DSTV Now.
I have a 4tb 2.5" portable hard drive connected to it for playing downloaded content.
One can format a USB stick to be used as part of the internal storage. So don't worry to much about the 8gb.
I love mine and would replace it in a heartbeat if it breaks.
