XP sp3 internet problems
sitnet
After installing Sp3 for Xp (the first beta version) I can't connect to the internet. When I restore my computer back to Sp2 everything works again.:confused: What should I do to fix this?
Dont install it again? No just joking. Download the latest 1. I think its available on the ms website. But I stand to be corrected!
lol... I think your solution is pretty obvious. :D
btw... you might want to read up on the definition of "Beta Software" ;)
"beta"...means testing dude so there will be teething problems you need to contact MS so that the developers are aware and they fix it..
