QuiXilver ZA
Hi all
I just moved into a complex in CT where the dstv points are in the wall. There's 3 points in the lounge, 2 for the HD; the 3rd point is a 'Return' point (that's what the label next to it reads).
In the bedroom there's a point in the wall. However this looks like a normal tv aerial point.
I have 2 decoders, viz. the hdpvr2p and a 1131; each will be connected to a different tv in a different room. The hd decoder is currently connected to the 2 points in the lounge.
I've made my own cables and bought a splitter - Game in Canal Walk just had a 4way splitter. I've connected one cable from the 'RF In' of the HD decoder to the 'In' port of the splitter. Then I have another cable going from one of the 4 'Out' ports of the splitter to the 'RF Out' of the second decoder.
2 Questions:
1) Is the above mentioned setup correct up to that point?
2) How do I connect the cable from the lnb to the second decoder? I did see a cable that has the co-ax aerial on one end and the f connector on the other end. I'm thinking of buying that if someone can confirm that they've used it and it works. My idea was to use that in the bedroom after sending another cable from the splitter to the 'Return' port I mentioned above.
Has anyone successfully implemented this setup before?
Thanks in advance for any advice.
2 Questions:
