Sapphiron
Hi all
I have got a client who has a few data captures. most of the PC's are second hand buys of various spec, most of them P3 range with only 128mb of ram
They have got windows 98, 2000, and even windows XP running on them
The data capturers basically just type their info onto a web from. i am going to recommend that we dump all the windows OS's and go with linux.
I am pretty sure it's gonna be Xubuntu.
Thus getting rid of the buggy windows 98 OS's, negating the need for antivirus and standardizing all the Data capturing PC's.
I need some advice from guys who have run Xubuntu in production situations like this:
Thanks to all in advance
- Is 128MB enough for Xubuntu running firefox and occasionally openoffice - dont want any memory dumping onto hard drive
- would 6.06 use less resources than 7.04?
- hardware compatability of 6.06 vs 7.04 (would 7.04 not include support for older hardware?)
- The normal CD install needs 192mb of ram - is that simply because the installer needs to run while a "session" is running
- How do I ensure that the "minimum" is running after the installation? is checking the services control enough?
