Ysie masjien - how does it work?
padjakkels
Northern Cape
Any one know how it works?
I get the stand with the sealer, and the bucket at the top.
Question is, how do you load the bags (on a roll) and how do you regulate the amount of liquid.
Thinking of building my own.
Then you also get pyramid shape ysies. How do you twist the bag and then seal it?
Thanks!
Im guessing you feed the plastic onto the rod under the bucket then release enough fluid with the tap on the rod for one and seal then repeat.
Fill the long bag From bottom to top. When full use the melting iron to seal the bags from the bottom up cutting it and sealing it into pieces/sizes of your liking. That's what it looks like from a distance.
Thanks Pitbull... just scared that the melting iron(sealer) won't last that long when it melt and going through the liquid. But I did manage to order a new one from someone, and the instructions are with it. Will see how it works, can't wait. The cost per ysie is about 1/4 to 1/5 what you pay for the final product.
Gonna use it for private and help some organisations to raise some money.
Its also easy to get the ice cream of juice that you put in.
Ooo If you can get those milk ysie thingies sorted. I LOVE THOSE :drool:
Yeah, already ordered the ice cream for the milk ysies. Will get it today but the machine only next week!
Will email you some milk ysies then! ;-)
