Zero-point energy
Benedict A55h0le not
There was this dude who built a car that ran on water. He was viewed as mad but after he died they got hold of his water powered car and found it was not really water powered. The energy source was 2 coiled rings that tapped into zero-point energy.
"Zero-point energy refers to random quantum fluctuations of the electromagnetic (and other) force fields that are present everywhere in the vacuum; in other words, an 'empty' vacuum is actually a seething cauldron of energy."
Hmmm, who profits from this? Sounds socialist to me.
It is suppressed by the oil cartels, since it can not be controlled like fossil resources. A zero-point energy source can be tiny and have no moving parts. So it can not be controlled by socialist governments (who are in bed with fossil fuel cartels).
Do you realise how stupid they are? They could multiply their profits if they didn't have to use their own product to transport their product to market! Idiots!
Q: Who proved the existence of zero point energy and virtual particles?
The combination of work by Hendrik Casimir and Steve Lamoreaux proved that zero point energy was real and that virtual particles exist everywhere in space.
Hi my name is John
Im 15 years old i just wanted to show that my generation still has hope
I've been working on this theorem.It's very basic and it will require a lot of work but i am willing to dedicate my
whole life to make it true.Here it is. I know it's not the right thread.
For any object, the loundounium(my made up name) percentage (L) can be calculated by dividing the number of inhibiting forces (A) by the total number of possible outcomes or things that can happen to the object (x), and then multiplying by 100.
Statement of the theorem: For any object, the loundounium percentage is given by L = (A / x) * 100.
Proof: To prove the theorem, we need to show that the loundounium percentage formula accurately represents the relationship between inhibiting forces and possible outcomes.
Let's assume an object with a certain number of inhibiting forces, A, and a total number of possible outcomes or things that can happen to the object, x.
According to the theorem, the loundounium percentage (L) is calculated as L = (A / x) * 100.
To establish the proof, we need to demonstrate that the loundounium percentage accurately represents the ratio of inhibiting forces to possible outcomes.
By dividing the number of inhibiting forces, A, by the total number of possible outcomes, x, we obtain the ratio A / x. Multiplying this ratio by 100 gives us the loundounium percentage.
The loundounium percentage represents the relative strength or impact of inhibiting forces on the possible outcomes for the object. By dividing A by x, we scale this ratio to a percentage, which provides a measure of the inhibitory influence on the object.
Therefore, the formula L = (A / x) * 100 correctly represents the loundounium percentage for an object based on the given assumptions. I asked Chat-GPT about some of its possibe uses and this it what it showed
  1. Physical systems analysis: The theorem could be applied to analyze physical systems where inhibiting forces play a significant role. By quantifying the inhibiting forces in relation to the range of possible outcomes, it may help in understanding the limitations or constraints on the system's behavior.
  2. Energy efficiency analysis: In energy-related fields, the theorem could be used to evaluate the efficiency of processes by considering the inhibiting forces that restrict the desired outcomes. By quantifying these inhibiting forces relative to the total potential outcomes, it may assist in identifying areas for improvement or optimizing energy utilization.(this is for you eskom)
  3. Particle interactions: The concept of loundounium could potentially be extended to describe the influence of inhibiting forces on particle interactions. It could aid in analyzing the impact of external factors on the behavior of particles and the range of possible outcomes in particle physics experiments.
  4. Stability analysis: The theorem could be relevant in assessing the stability of physical systems. By quantifying the inhibiting forces compared to the possible outcomes, it may help determine the likelihood of system stability or the need for additional control mechanisms to counterbalance the inhibiting forces.
  5. Optimization problems: The loundounium theorem might be applicable in certain optimization problems in physics. By considering the inhibiting forces and their impact on the range of possible outcomes, it could guide the development of strategies to optimize the system's performance or achieve desired objectives. Obviously i still need to find out the Number of things that can happen to an object at any possible time and a universal unit of measurement of forces. (mabye N) but it will all happen in time. Thanks to anyone who took their hard earned time to read a 15 year old's theorem
Hi my name is John
Talk about commitment. Good job
Hi my name is John
wow absolutely astonishing to even see an attempt of a theorem by a 15 year old. Guess the old generation got to learn that there are good and bad apples in every bunch
People sure hate it when I say their beloved DA is socialist. The DA is socialist.
Democratic socialism is the best option we have, at present. It's dat or move to Orangetown.
Hi my name is John
don't get cheeky !
don't get cheeky !
Stargate had it first
LOL at all the dumb Saffer close mindedness. It was proven to be real, you are welcome to post links that state otherwise. Good slow boiled frogs by the oil cartels.
Not in single link to any reading material.
Friday came early I see.
