IRG, don't suppose you have figures from just running the V8 without lapping it?
I have the cooler master V8, its contact surface area was milled and pretty much level. So I did not lap that. I did lap my Q6600, man was that uneven! My Wife also runs the Q6600, stock cooler and stock speeds. At Idle I run about 26C under load 41C, My wife's runs idle @ 34C and load at 55C. My Q6600 is Oc'd to 3.0ghz from 2.4ghz. So yeah theres a nice improvement. Before the lapping and V8 I would hit 65C - 70C easy under load (using prime95).
How do you know the lapping made any difference? Did you test it or something? The conditions the exact same?
The other thing that bugs me with lapping a CPU is static build up. All that rubbing should wind up building static on the CPU, or so it would seem to me.
I've been thinking of getting the TRUE in a few months time. I've seen the concave base issue so I assume flattening it enough would not need CPU lapping. Really have no hassle with heatsink lapping, but CPU lapping I'm not too keen on.
