Until about 2 months ago I was using a Planet ADE-3100 ADSL router, which worked very well for me. Then my line started giving issues, and I had a Telkom techie fix it (took almost a week). During this time I kept my Planet on the line, and when the line was repaired my Planet would no longer sync. I suspect something done during the fixing destroyed the DSL hardware inside it. My mistake there.
I switched over to my backup modem (a Billion BiPAC 5200S RC). I did find it strange that my line attenuation was worse after the repair than before. I also had sporadic ADSL sync loss on the line, lasting about 3-4s. So I eventually (about 3 weeks ago) borrowed a friend's Billion BiPAC 5200S (non-RC model), and all my issues went away. So I decided to test two different lines (in the tables below, upstream is first, followed by downstream):
Line 1 (Home):
Billion 5200S
SNR Margin: 12.1 10.8 db
Line Attenuation: 44.0 27.0 db
Data Rate: 6144 635 kbps
Billion 5200S RC
SNR Margin: 16.5 16.6 db
Line Attenuation: 70.0 28.0 db
Line 2:
Billion 5200S
SNR Margin: 15.0 13.0 db
Line Attenuation: 43.0 19.0 db
Data Rate: 4096 512 kbps
Billion 5200S RC
SNR Margin: 22.5 13.0 db
Line Attenuation: 63.5 21.0 db
In both cases both the SNR Margin and the Line Attenuation is much worse on the RC than the non-RC. Obviously I can't return this, as the modem is working correctly.
Could this be a problem with the unit itself, or is this a general issue with the RC? Or perhaps the RC is reporting incorrect values?
Line 1 (Home):
Billion 5200S
Billion 5200S RC
Line 2:
Billion 5200S
Billion 5200S RC
