CntrlAltDel
- Jul 21, 2010
Hey everyone. So recently I bought a new CPU cooler that required me to take my entire motherboard out from my pc chase to install. So I do that and connect everything back. But I have 1 problem, which is that my USB and audio pins are dead confusing, the names on the pins dont seem to correspond with the names on given on the manual of my motherboard.
The USB front panel extension consists of 2x USB slots and 1x Audio and 1x Mic input. Even the audio and mic inputs are confusing.
Front Panel Audio:
The layout of my motherboards pins can be seen here http://www.mybroadband.co.za/photos/data/2/Front_Panel_Audio.jpg
Those which are connected to the front panel of the audio slots however are:
Green Wire - Spkout R
White Wire - Spkout L
Grey Wire - Spkout L
Blue Wire - Return L
Black Wire - Ground
Peach Wire - Mic In
Yellow Wire - Mic BIAS
The layout of my motherboards USB front panel connections looks like this http://www.mybroadband.co.za/photos/data/2/USB_Front_Panel_Headers.jpg
Those which are connected to the front panel of the USB slots however are:
Red Wire - +VCC
Yellow Wire - -D
Green Wire - +D
Black Wire - Ground
There are 2 sets of cables, one of USB front panel slot on and the other for USB front panel slot 2.
I have sorted out the USB slots but the audio still needs sorting out
Front Panel Audio:
Black Wire - Ground
Peach Wire - Mic In
Red Wire - +VCC
Yellow Wire - -D
Green Wire - +D
Black Wire - Ground
