kernel
Dealer
Hi Guys
The last of our product give aways with a little twist....
The product give away is for a TP-LINK TL-WDR4300 750mbps Dual Band Wireless-N Router valued at R1080 (incl vat)
How the competition works.....
First, you'll need to like us on Facebook (http://www.facebook.com/unitermdirect)
Then you need to correctly answer a question, first correct answer posted on this forum topic after 12pm (or closest time thereafter) on Friday 31st August 2012 wins, if you've not liked us on Facebook you will not qualify for the competition, a verification code will be sent via PM on the MYBB site which needs to be posted on our wall as confirmation once the competition has run its course.
Your prize will be delivered free of charge (SA only).
Question: How many LAN, WAN and USB ports does the TL-WDR4300 have?
Terms and Conditions:
Edited posts will not count
If multiple posts at the same time are posted, the post that appears first (after 12pm) on the forum will win (providing you've liked us on Facebook)
MYBB members who have won a prize from Uniterm Direct within the last 6 months will no be eligible to win
You may not enter the competition if you are a director, member, partner, employee of MyBroadband (MYBB), MYBB site administrators and / or site moderator are also not allowed to take part in the competition.
In order to qualify, you have to like us on Facebook, if you have not done this your post will not count and the first correct answer posted by a MYBB member after 12pm will be the winner.
Uniterm Direct's decision is final and no correspondence will be entered into
