Mars Rover could contaminate potential water supply on Mars
Mars Rover could contaminate potential water supply on Mars or reintroduce microbes(life) in the mars environment. How neat and what a lot of hogwash, contaminate Mars indeed!.
Please note, hippies - this is not a tie-dye template ffs:
After spending 9 months in the vaccuum of space, are there any bacteria left that will make any meaningful difference?
Can only happen if the rover decides to take a piss in the water supply(?) And expose his bits to the bacteria.
What next, rovers gaseous discharge could contaminate the martian air.
my brainy wife says some are anaerobic. i would have guessed that's someone that doesn't do aerobics. which means they don't need oxygen. apparently they're very versatile.
Despite what creationists will try to tell you, simple microorganisms possibly traveled through space on their asteroid taxis and started life on Earth.
