Hi,
New and seeking some advice.
I upgraded my afrihost adsl account to 20mb uncapped VDSL line and data at afrihost.
For a while i have noticed that the speed i receive is between 10 and 12mb if i am lucky.
I noticed the modulation also still says adsl. I plugged in my adsl modem and saw that the adsl modem works on the vdsl line. Then i contacted the supplier of the modem TPlink and they replied that the modem i use will never work on an vdsl line.
When i contacted Afrihost to ask how it is possible, they replied that the line and package is on vdsl but because the modulation is not on vdsl, it can operate adsl and vdsl.
Why do we need to buy VDSL modems if a ADSL modem is compatible with vdsl line, even if it is not designed for it?
It makes a person wonder, how may isp has informed the customer to buy a vdsl modem for nothing. I spend just under 1000 for a vdsl modem thanks to afrihost and then i find out my non compatible adsl modem works on the vdsl line just fine.
My Questions are:
Has this happened to anyone before that you can run a vdsl connection from an ADSL modem that is only designed for adsl?
Are the minimum speed for 20 mb vdsl constantly 24/7 between 10 and 12mb?
thanx
My Questions are:
thanx
