MTN Broadband Speed Test Results
MrG
Hi Forumites!!!
There are many members that wonder how their MTN Broadband performs in comparison with other wirless broadband users.
If you have some spare time please do the Telkom speed test and give your area and tower you logon to, aslo state if you are using GPRS, EDGE or 3G. State wether you are connecting with a phone/modem (please give model and manufacturer name). Speed test URL: http://www.telkom.co.za/minisites/dsl/speed.html
Thanks and regards,
Mr.G
Results:
Below is the data used to calculate your download speed:
* Download time: 110.479 seconds
* Size of file: 500 KiloBytes
* Estimated line speed: 36.9 (kilobits/second)
* Estimated line speed: 4.5 (kiloBytes/second)
MTN GPRS on VodaFone Mobile Connect Data Card
Friends results:
Download time: 202.36 seconds
Estimated line speed: 20.2 (kilobits/second)
Estimated line speed: 2.5 (kiloBytes/second)
MTN GPRS on Nokia 6670 - Kenridge ,Cape Town
Interesting comparing to others. This is in Kuilsrivier and is not Edge covered. My speed in PE is better (due to edge). It is via Bluetooth on a Nokia 6230 - MTN.
Download time: 89.719 seconds
Estimated line speed: 45.5 (kilobits/second)
Estimated line speed: 5.6 (kiloBytes/second)
Obronie
Using Edge with a Rx lvl of -91 and C1 / C2 of 20 / 4 on a Nokia 6630
Download time: 27.328 seconds
Estimated line speed: 149.3 (kilobits/second)
Estimated line speed: 18.3 (kiloBytes/second)
Download time: 134.393 seconds
Estimated line speed: 30.4 (kilobits/second)
Estimated line speed: 3.7 (kiloBytes/second)
Nikia 6680 - as you can see MTN sucks in Cullinan / Boschkop.
VODACOM
* Download time: 63.016 seconds
* Estimated line speed: 64.7 (kilobits/second)
* Estimated line speed: 7.9 (kiloBytes/second)
using EDGE/GPRS usb modem off my laptop in Northern Drakensberg.
MTN
* Download time: 94.203 seconds
* Estimated line speed: 43.3 (kilobits/second)
* Estimated line speed: 5.3 (kiloBytes/second)
As you can see Vodacom is faster here than MTN. I also have erratic MTN reception.
It remains fun to sit in a Caravan park with internat acess faster than telkom dial up!!
In Pta I normally use MTN due to lower data bundle cost. In areas with EDGE coverage MTN is a lot faster than VODA.
A 3G Voda tower is being erected near my home in PTA. I will be upgrading to 3 G in Jan!!
Recommendations of cards will be appreciated.
I'm using MTN 3G in Raslouw, Centurion with 3/5 signal strength.
Download time: 42.984 seconds
Estimated line speed: 94.9 (kilobits/second)
Estimated line speed: 11.6 (kiloBytes/second)
Looking at Sparky za's EDGE speed, my 3G is a bit dissapointing...
BUT at least is it always at +- 11.5 KBs/sec...
My MTN connections "dies" multiple times a day. My connection sends data but receives nothing. It's not the data card or the phone as Vodacom works perfectly on both. Vodacom is also "faster" in PTA East.
Hey all,
In PE (3G) using a Nokia 6680, with full signal.
Results:
* Download time: 13.349 seconds
* Estimated line speed: 305.6 (kilobits/second)
* Estimated line speed: 37.5 (kiloBytes/second)
Ping results:
Pinging telkomsa.net [196.25.211.40] with 32 bytes of data:
Reply from 196.25.211.40: bytes=32 time=197ms TTL=115
Reply from 196.25.211.40: bytes=32 time=206ms TTL=115
Reply from 196.25.211.40: bytes=32 time=204ms TTL=115
Ping statistics for 196.25.211.40:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 197ms, Maximum = 206ms, Average = 201ms
Not too shaby :)
Cheers, Nick
Using Novatel 3G card in Krugersdorp over MTN GPRS ( as no EDGE nor 3G in the heart of Mogale City - opposite the Mogale City Muncipical Centre which is the CBD of Krugersdorp and the heart of the West Rand AND WHERE VODACOM HAS 3G ):
Results:
Download time: 87.828 seconds
Estimated line speed: 46.5 (kilobits/second)
Estimated line speed: 5.7 (kiloBytes/second)
and Vodacom gives me about 280 kilobits/ second in the same spot ! ( Check the Vodacom thread )
Just thought I would add this in for comparison.
Using my Nokia 6630 on GPRS, Rx lvl of -20 and C1 of 90. We have a MTN Microcell in our server room, which is why the signal is so good. They may make it EDGE compatible, if they do I will post again.
Results:
Download time: 87.563 seconds
Estimated line speed: 46.6 (kilobits/second)
Again, Nokia 6630, but this time on 3G with about half signal strength. Can't give the exact figures cause the program I have doesn't seem to work on 3G
Results:
Download time: 14.219 seconds
Estimated line speed: 286.9 (kilobits/second)
Estimated line speed: 35.2 (kiloBytes/second)
Results from Lynnwood Pta
I am connected with a Nokia 6230 (EDGE-enabled) and a Bluetooth connection to my PC.
Signal strength: Very good.
Results:
* Download time: 26.953 seconds
* Estimated line speed: 151.4 (kilobits/second)
* Estimated line speed: 18.6 (kiloBytes/second)
3G resuts
This is using MTN 3G from Port Elizabeth 3/5 bars signal strength.
Download time: 11.875 seconds
Estimated line speed: 343.6 (kilobits/second)
Estimated line speed: 42.1 (kiloBytes/second)
I wish I could do this at my house in Midrand :(
Sparky_za said:
AFAIK you have to be in a 3G zone with one of the new 128K Sim cards
You need to be in 3G Coverage, 32K Sim Card will suffice
Again in Krugersdorp - this time i used a Nokia 9300, hoping that MTN had activated EDGE in Krugersdorp CBD --but alas --still GPRS speeds :
Results:
Download time: 84.734 seconds
Estimated line speed: 48.2 (kilobits/second)
Estimated line speed: 5.9 (kiloBytes/second)
